Ana içeriğe geç
Canon PowerShot A2200 Front Cover Replacement
Neye ihtiyacın var
  1. Canon PowerShot A2200 Front Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Front Cover Replacement: adım 2, 1 resimden 1.
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Front Cover Replacement: adım 3, 1 resimden 1.
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Front Cover Replacement: adım 4, 3 resimden 1. Canon PowerShot A2200 Front Cover Replacement: adım 4, 3 resimden 2. Canon PowerShot A2200 Front Cover Replacement: adım 4, 3 resimden 3.
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Front Cover Replacement: adım 5, 3 resimden 1. Canon PowerShot A2200 Front Cover Replacement: adım 5, 3 resimden 2. Canon PowerShot A2200 Front Cover Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
  6. Canon PowerShot A2200 Front Cover Replacement, Button Assembly: adım 6, 2 resimden 1. Canon PowerShot A2200 Front Cover Replacement, Button Assembly: adım 6, 2 resimden 2.
    • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
    • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
  7. Canon PowerShot A2200 Front Cover Replacement: adım 7, 1 resimden 1.
    • Gently lift of the buttons for replacement. They should come off without excessive force.
    • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
  8. Canon PowerShot A2200 Front Cover Replacement, LCD Screen: adım 8, 1 resimden 1.
    • Lift up the electrical ribbon shown to access the next screw.
    • Remove the 3.9 mm screw with a Phillips #00 screwdriver.
  9. Canon PowerShot A2200 Front Cover Replacement: adım 9, 1 resimden 1.
  10. Canon PowerShot A2200 Front Cover Replacement: adım 10, 1 resimden 1.
    • Remove the two 3.9 mm screws shown with a Phillips #00 screwdriver.
  11. Canon PowerShot A2200 Front Cover Replacement: adım 11, 2 resimden 1. Canon PowerShot A2200 Front Cover Replacement: adım 11, 2 resimden 2.
    • There is an electrical flap that holds the LCD ribbon down. Note the flap in is closed position.
    • Lift up the flap with a plastic opening tool.
  12. Canon PowerShot A2200 Front Cover Replacement: adım 12, 1 resimden 1.
    • Holding the outer frame of the LCD screen, gently lift the LCD screen for replacement.
  13. Canon PowerShot A2200 Front Cover Replacement: adım 13, 3 resimden 1. Canon PowerShot A2200 Front Cover Replacement: adım 13, 3 resimden 2. Canon PowerShot A2200 Front Cover Replacement: adım 13, 3 resimden 3.
    • This step is only for replacement. If you are not replacing the LCD screen, skip this step.
    • Locate ribbon flap, enclosed in red. (picture 1)
    • Using a plastic opening tool, lift up the ribbon flap to allow insertion of the LCD ribbon. (picture 2)
    • Place the LCD screen on the camera and align the ribbon underneath the open ribbon flap. Close the ribbon flap onto the ribbon. (picture 3)
  14. Canon PowerShot A2200 Front Cover Replacement, Lens Assembly: adım 14, 1 resimden 1.
    • Remove the two 5.3 mm screws circled in red with a Phillips #00 screwdriver.
    • Remove the 4.4 mm screw circled in orange with a Phillips #00 screwdriver.
  15. Canon PowerShot A2200 Front Cover Replacement: adım 15, 2 resimden 1. Canon PowerShot A2200 Front Cover Replacement: adım 15, 2 resimden 2.
    • Gently press the front of the lens to begin to remove it from the frame.
    • Gently angle out the lens from the frame as seen in picture 2.
    • A thin circular ribbon should fall out from the front of the lens. Note its original location on the front cover for reassembly.
  16. Canon PowerShot A2200 Front Cover Replacement: adım 16, 3 resimden 1. Canon PowerShot A2200 Front Cover Replacement: adım 16, 3 resimden 2. Canon PowerShot A2200 Front Cover Replacement: adım 16, 3 resimden 3.
    • Locate the two electrical ribbons that are attached to the main motherboard.
    • Lift up the two black flaps on the motherboard that hold the electrical ribbons in place.
    • Gently remove the lens for replacement.
  17. Canon PowerShot A2200 Front Cover Replacement, Front Cover: adım 17, 1 resimden 1.
    • Remove the two 4.4 mm screws shown with a Phillips #00 screwdriver.
  18. Canon PowerShot A2200 Front Cover Replacement: adım 18, 1 resimden 1.
    • Remove the 4.4 mm screw shown with a Phillips #00 screwdriver.
  19. Canon PowerShot A2200 Front Cover Replacement: adım 19, 1 resimden 1.
    • Gently remove the front cover for replacement.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Benjamin Gee
929 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G5
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 1,032
