Ana içeriğe geç
Canon PowerShot A2300 Front Cover Replacement
Neye ihtiyacın var
  1. Canon PowerShot A2300 Front Cover Replacement, Front Cover: adım 1, 1 resimden 1.
    • Open the A/V Out Digital port cover on the function button side to reveal a screw.
  2. Canon PowerShot A2300 Front Cover Replacement: adım 2, 3 resimden 1. Canon PowerShot A2300 Front Cover Replacement: adım 2, 3 resimden 2. Canon PowerShot A2300 Front Cover Replacement: adım 2, 3 resimden 3.
    • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
    • Screws are small and very easily lost.
  3. Canon PowerShot A2300 Front Cover Replacement: adım 3, 2 resimden 1. Canon PowerShot A2300 Front Cover Replacement: adım 3, 2 resimden 2.
    • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
    • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
  4. Canon PowerShot A2300 Front Cover Replacement: adım 4, 1 resimden 1.
    • Gently lift the bottom of the front cover to roughly a 30 degree angle.
  5. Canon PowerShot A2300 Front Cover Replacement: adım 5, 1 resimden 1.
    • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ashley Fincher
495 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 7-14, Williams Spring 2015 Baylor, Team 7-14, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S7G14
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Are the screws really hard to remove, or is it just me?
Alex Hulinsky - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 30
Her zaman: 692
