Ana içeriğe geç
Canon PowerShot A2500 Body Casing and Faceplate Replacement
Neye ihtiyacın var
  1. Canon PowerShot A2500 Body Casing and Faceplate Replacement, Body Casing and Faceplate: adım 1, 2 resimden 1. Canon PowerShot A2500 Body Casing and Faceplate Replacement, Body Casing and Faceplate: adım 1, 2 resimden 2.
    • Remove the knot holding the wrist lanyard onto the camera
  2. Canon PowerShot A2500 Body Casing and Faceplate Replacement: adım 2, 1 resimden 1.
    • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
    • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
    • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
  3. Canon PowerShot A2500 Body Casing and Faceplate Replacement: adım 3, 3 resimden 1. Canon PowerShot A2500 Body Casing and Faceplate Replacement: adım 3, 3 resimden 2. Canon PowerShot A2500 Body Casing and Faceplate Replacement: adım 3, 3 resimden 3.
    • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
  4. Canon PowerShot A2500 Body Casing and Faceplate Replacement: adım 4, 3 resimden 1. Canon PowerShot A2500 Body Casing and Faceplate Replacement: adım 4, 3 resimden 2. Canon PowerShot A2500 Body Casing and Faceplate Replacement: adım 4, 3 resimden 3.
    • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
    • Be careful not to bend the plastic casing to much, as it will crack.
Sonuç
Bir başkası bu kılavuzu tamamladı.
James Hickey
393 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-4, Duarte Spring 2015 UMass Dartmouth, Team 3-4, Duarte Spring 2015 üyesi
UMASSD-DUARTE-S15S3G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 389
