Ana içeriğe geç
Canon PowerShot A3400 IS Plastic Case Replacement
Neye ihtiyacın var
  1. Canon PowerShot A3400 IS Plastic Case Replacement, Battery: adım 1, 1 resimden 1.
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Canon PowerShot A3400 IS Plastic Case Replacement: adım 2, 1 resimden 1.
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Canon PowerShot A3400 IS Plastic Case Replacement, Plastic Case: adım 3, 2 resimden 1. Canon PowerShot A3400 IS Plastic Case Replacement, Plastic Case: adım 3, 2 resimden 2.
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Canon PowerShot A3400 IS Plastic Case Replacement: adım 4, 2 resimden 1. Canon PowerShot A3400 IS Plastic Case Replacement: adım 4, 2 resimden 2.
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Canon PowerShot A3400 IS Plastic Case Replacement: adım 5, 1 resimden 1.
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Canon PowerShot A3400 IS Plastic Case Replacement: adım 6, 1 resimden 1.
    • Remove the 5.00 mm screw from behind the cover.
  7. Canon PowerShot A3400 IS Plastic Case Replacement: adım 7, 1 resimden 1.
    • Make sure the battery cover is open.
  8. Canon PowerShot A3400 IS Plastic Case Replacement: adım 8, 2 resimden 1. Canon PowerShot A3400 IS Plastic Case Replacement: adım 8, 2 resimden 2.
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  9. Canon PowerShot A3400 IS Plastic Case Replacement: adım 9, 3 resimden 1. Canon PowerShot A3400 IS Plastic Case Replacement: adım 9, 3 resimden 2. Canon PowerShot A3400 IS Plastic Case Replacement: adım 9, 3 resimden 3.
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  10. Canon PowerShot A3400 IS Plastic Case Replacement: adım 10, 3 resimden 1. Canon PowerShot A3400 IS Plastic Case Replacement: adım 10, 3 resimden 2. Canon PowerShot A3400 IS Plastic Case Replacement: adım 10, 3 resimden 3.
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emily Pretorius
325 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Sullivan Winter 2015 USF Tampa, Team 1-1, Sullivan Winter 2015 üyesi
USFT-SULLIVAN-W15S1G1
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 237
