Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Parçalar
Hiçbir parça belirtilmedi.
  1. First remove the batteries and memory card. Remove the screws for the back cover (circled in red) with a Phillips head screwdriver (PH000) .
    • First remove the batteries and memory card.
    • Remove the screws for the back cover (circled in red) with a Phillips head screwdriver (PH000) .
  2. The back cover can be gently pried off after the screws are removed.
    • The back cover can be gently pried off after the screws are removed.
  3. Remove the three screws outlined in the pictures. Remove the three screws outlined in the pictures.
    • Remove the three screws outlined in the pictures.
  4. The ribbon for the screen is folded under the plate. Carefully unfold the ribbon by flipping the screen face down next to the camera. Underneath the plate the connection between the camera and the ribbon can be viewed.
    • The ribbon for the screen is folded under the plate. Carefully unfold the ribbon by flipping the screen face down next to the camera.
    • Underneath the plate the connection between the camera and the ribbon can be viewed.
  5. The metal frame of the screen can be removed using a thin spatula or spudger. After the frame is removed the part of the ribbon connected to the screen is accessible.
    • The metal frame of the screen can be removed using a thin spatula or spudger. After the frame is removed the part of the ribbon connected to the screen is accessible.
Sonuç
Ansley Gardner
761 İtibar
7 adet Kılavuz yazıldı
Takım
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014 üyesi
CLEM-BENSON-F14S1G3
3 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
Completely worthless repair guide! Do not try before reading below!
In Step 4, this guide neglects to mention at all if you raise the plate too high to get to the screen ribbon connector, you will DISCONNECT the ribbon connector “north” (above) it for all the controls and, apparently, power on/off. And if you disconnect this second connector, you are S.O.L. as there is no way to remove the plate completely to reconnect it (the ribbon has nearly zero length/play in it) and the ribbon/control board cannot be completely detached from the plate to give you more length/play as there is a THIRD ribbon connector between the plate and microphone from the control board that dives deep into the innards of the camera.
So because I wasn’t warned and lifted the plate a little too high, I disconnected the controls/power connector with no good way as an average person at home with limited tools or camera repair skills to reseat it, and now have a $20 new LCD screen in a camera that won’t turn on.
Thanks, fixit! >:(
sloe_mule - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 897
