Ana içeriğe geç
Canon PowerShot A460 Front Casing Replacement
Neye ihtiyacın var
  1. Canon PowerShot A460 Front Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 Front Casing Replacement: adım 2, 1 resimden 1.
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 Front Casing Replacement: adım 3, 1 resimden 1.
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 Front Casing Replacement, Front Casing: adım 4, 1 resimden 1.
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 Front Casing Replacement: adım 5, 1 resimden 1.
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 Front Casing Replacement: adım 6, 1 resimden 1.
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 Front Casing Replacement: adım 7, 1 resimden 1.
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 Front Casing Replacement: adım 8, 2 resimden 1. Canon PowerShot A460 Front Casing Replacement: adım 8, 2 resimden 2.
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 Front Casing Replacement: adım 9, 3 resimden 1. Canon PowerShot A460 Front Casing Replacement: adım 9, 3 resimden 2. Canon PowerShot A460 Front Casing Replacement: adım 9, 3 resimden 3.
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 Front Casing Replacement: adım 10, 3 resimden 1. Canon PowerShot A460 Front Casing Replacement: adım 10, 3 resimden 2. Canon PowerShot A460 Front Casing Replacement: adım 10, 3 resimden 3.
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
Sonuç
Alex
85 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-42, Regan Winter 2013 Cal Poly, Team 19-42, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G42
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 949
