Ana içeriğe geç
Canon PowerShot A460 Front Lens Replacement
Neye ihtiyacın var
  1. Canon PowerShot A460 Front Lens Replacement, Battery: adım 1, 1 resimden 1.
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 Front Lens Replacement: adım 2, 1 resimden 1.
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 Front Lens Replacement: adım 3, 1 resimden 1.
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 Front Lens Replacement, Front Casing: adım 4, 1 resimden 1.
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 Front Lens Replacement: adım 5, 1 resimden 1.
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 Front Lens Replacement: adım 6, 1 resimden 1.
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 Front Lens Replacement: adım 7, 1 resimden 1.
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 Front Lens Replacement: adım 8, 2 resimden 1. Canon PowerShot A460 Front Lens Replacement: adım 8, 2 resimden 2.
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 Front Lens Replacement: adım 9, 3 resimden 1. Canon PowerShot A460 Front Lens Replacement: adım 9, 3 resimden 2. Canon PowerShot A460 Front Lens Replacement: adım 9, 3 resimden 3.
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 Front Lens Replacement: adım 10, 3 resimden 1. Canon PowerShot A460 Front Lens Replacement: adım 10, 3 resimden 2. Canon PowerShot A460 Front Lens Replacement: adım 10, 3 resimden 3.
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
  11. Canon PowerShot A460 Front Lens Replacement, Back Casing: adım 11, 1 resimden 1.
    • Remove the back case of the camera by pulling from the top.
    • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
  12. Canon PowerShot A460 Front Lens Replacement, LCD Screen: adım 12, 1 resimden 1.
    • Remove the 4mm Phillips #00 screw from above the ribbon.
  13. Canon PowerShot A460 Front Lens Replacement: adım 13, 1 resimden 1.
    • Gently peel off the blue tape on the top of the LCD screen.
  14. Canon PowerShot A460 Front Lens Replacement: adım 14, 1 resimden 1.
    • Remove the 4mm Phillips #00 screw previously concealed by the blue tape.
  15. Canon PowerShot A460 Front Lens Replacement: adım 15, 1 resimden 1.
    • Gently lift the LCD screen off of the front casing by pulling up a tab on the side of the camera.
  16. Canon PowerShot A460 Front Lens Replacement: adım 16, 1 resimden 1.
    • Using a spudger, lift the grey tabs to allow the ribbon to slide out.
  17. Canon PowerShot A460 Front Lens Replacement: adım 17, 1 resimden 1.
    • Since the tabs have been lifted, the ribbon should now slide out out easily.
    • Be careful not to distort the ribbon in any way.
  18. Canon PowerShot A460 Front Lens Replacement, Motherboard: adım 18, 1 resimden 1.
    • Remove the 5mm Phillips #00 screw located above the small black piece on the right side of the mother board.
  19. Canon PowerShot A460 Front Lens Replacement: adım 19, 2 resimden 1. Canon PowerShot A460 Front Lens Replacement: adım 19, 2 resimden 2.
    • Remove the 4mm Phillips #00 screw at the bottom of the black piece.
    • Detach the black piece that the screws previously held in place.
  20. Canon PowerShot A460 Front Lens Replacement: adım 20, 1 resimden 1.
    • Remove the 5mm Phillips #00 screw in the middle of the motherboard.
  21. Canon PowerShot A460 Front Lens Replacement: adım 21, 1 resimden 1.
    • Remove the 5mm Phillips #00 screw that holds the metal piece to the bottom of the camera .
  22. Canon PowerShot A460 Front Lens Replacement: adım 22, 1 resimden 1.
    • Remove the 5mm Phillips #00 screw that is located on the top of camera.
  23. Canon PowerShot A460 Front Lens Replacement: adım 23, 1 resimden 1.
    • Remove the 2mm Phillips #00 screw that is located on the far left of the motherboard.
    • Be careful not to damage the multiple adjacent orange ribbons.
  24. Canon PowerShot A460 Front Lens Replacement: adım 24, 1 resimden 1.
    • Remove the 5mm Phillips #00 screw near the bottom left of the motherboard.
  25. Canon PowerShot A460 Front Lens Replacement: adım 25, 2 resimden 1. Canon PowerShot A460 Front Lens Replacement: adım 25, 2 resimden 2.
    • Using a spudger, unlock the locking mechanism that holds the lower orange ribbon in place.
    • Once unlocked, slide out the ribbon.
  26. Canon PowerShot A460 Front Lens Replacement: adım 26, 1 resimden 1.
    • Using a spudger, unlock the locking mechanism that holds the upper orange ribbon in place.
  27. Canon PowerShot A460 Front Lens Replacement: adım 27, 1 resimden 1.
    • All that is required is to unsolder the few remaining wires. Then, the motherboard will be ready to be replaced!
  28. Canon PowerShot A460 Front Lens Replacement, Front Lens: adım 28, 1 resimden 1.
    • Remove the six 2mm Phillips #00 screws that are located under the motherboard.
  29. Canon PowerShot A460 Front Lens Replacement: adım 29, 2 resimden 1. Canon PowerShot A460 Front Lens Replacement: adım 29, 2 resimden 2.
    • Remove the 4mm Phillips #00 screw that is located under the now disconnected top orange ribbon.
    • The lens piece can now be removed from the camera.
  30. Canon PowerShot A460 Front Lens Replacement: adım 30, 1 resimden 1.
    • Remove the 5mm Phillips #00 screw on the back of the lens piece.
  31. Canon PowerShot A460 Front Lens Replacement: adım 31, 1 resimden 1.
    • Remove the 2mm Phillips #00 screw on the bottom of the lens piece.
  32. Canon PowerShot A460 Front Lens Replacement: adım 32, 1 resimden 1.
    • Remove the two 2mm Phillips #00 screws on the top of the lens piece.
  33. Canon PowerShot A460 Front Lens Replacement: adım 33, 1 resimden 1.
    • Gently slide off the black piece surrounding the lens. The lens is now disassembled!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tanner Coleman
40 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-42, Regan Winter 2013 Cal Poly, Team 19-42, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G42
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
please put a big warning note on the step after removing the blue tape from the lens. and the next on is where you lift something on the mother board with a spluger..something like that. well i used a screwdriver and got such a big electrical shock.... scared the crapola out of me. please make a note .... can get electrical shock....
Gaby - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 72
Her zaman: 4,562
