Ana içeriğe geç
Canon PowerShot A480 Battery Replacement
Neye ihtiyacın var
  1. Canon PowerShot A480 Battery Replacement, Battery: adım 1, 3 resimden 1. Canon PowerShot A480 Battery Replacement, Battery: adım 1, 3 resimden 2. Canon PowerShot A480 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure to fully power off the camera before starting the replacement process.
    • Locate the battery door at the underside of your camera and orient it so that the door points to the right.
    • Gently apply downward pressure to the right edge of the door and slide to the right.
    • Once you hear an audible click, lift up the bay door in the opposite direction till the batteries are fully exposed.
  2. Canon PowerShot A480 Battery Replacement: adım 2, 3 resimden 1. Canon PowerShot A480 Battery Replacement: adım 2, 3 resimden 2. Canon PowerShot A480 Battery Replacement: adım 2, 3 resimden 3.
    • Ensure that the contacts for the batteries are free of any corrosion.
    • Gently tip the body of the camera towards your body to slide the batteries out.
    • Slide the batteries out enough to where you are able to grasp both of them for removal.
Sonuç
After obtaining two replacement AA batteries. To reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Kenneth Robertson
309 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Cardinal Spring 2019 UW Tacoma, Team S1-G5, Cardinal Spring 2019 üyesi
UWT-CARDINAL-S19S1G5
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Will the normal AA batteries work?
Viswanath harikumar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 23
Son 30 gün: 116
Her zaman: 3,258
