Ana içeriğe geç
Canon PowerShot A480 LCD Screen Replacement
Neye ihtiyacın var
  1. Canon PowerShot A480 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 1. Canon PowerShot A480 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 2. Canon PowerShot A480 LCD Screen Replacement, LCD Screen: adım 1, 3 resimden 3.
    • First, we will start by removing all of the black 5mm screws on the exterior.
    • Flip the camera upside down revealing two black screws on either side of the tripod mount.
    • Turn to the side of the camera closest to the lens to unscrew the third and final black screw.
  2. Canon PowerShot A480 LCD Screen Replacement: adım 2, 3 resimden 1. Canon PowerShot A480 LCD Screen Replacement: adım 2, 3 resimden 2. Canon PowerShot A480 LCD Screen Replacement: adım 2, 3 resimden 3.
    • Open the rubber panel on the side of the camera to reveal the last two 5mm exterior screws which are silver.
    • Once you have removed the last of the screws, use an iFixit opening tool to separate the two halves of the camera.
    • Take a half of the camera in each hand and gently pry them apart, pulling up on the side across from where the buttons are located.
  3. Canon PowerShot A480 LCD Screen Replacement: adım 3, 3 resimden 1. Canon PowerShot A480 LCD Screen Replacement: adım 3, 3 resimden 2. Canon PowerShot A480 LCD Screen Replacement: adım 3, 3 resimden 3.
    • With the screen now exposed, you must unscrew the three silver 2mm screws attaching it to the body of the camera.
    • Use the iFixit opening tool to lift the screen away from the body so that the only thing connecting it to the rest of the camera is the thin, orange wire cable.
    • Using your pointer finger and thumb, firmly grasp the cable and pull it straight away from the camera to disconnect it.
Sonuç
To reassemble your device, follow these instructions in reverse order using your new LCD display.
4 farklı kişi bu kılavuzu tamamladı.
Ian Nzabanita
193 İtibar
1 Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G5, Cardinal Spring 2019 UW Tacoma, Team S1-G5, Cardinal Spring 2019 üyesi
UWT-CARDINAL-S19S1G5
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 38
Her zaman: 1,461
