Ana içeriğe geç
Canon PowerShot A540 Back Cover Replacement
Neye ihtiyacın var
  1. Canon PowerShot A540 Back Cover Replacement, Back Cover: adım 1, 2 resimden 1. Canon PowerShot A540 Back Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 Back Cover Replacement: adım 2, 1 resimden 1.
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 Back Cover Replacement: adım 3, 1 resimden 1.
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 Back Cover Replacement: adım 4, 1 resimden 1.
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 Back Cover Replacement: adım 5, 3 resimden 1. Canon PowerShot A540 Back Cover Replacement: adım 5, 3 resimden 2. Canon PowerShot A540 Back Cover Replacement: adım 5, 3 resimden 3.
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Carley Fuller
434 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S7G12
3 Üyeler
20 adet Kılavuz yazıldı
Bir Yorum
Mon écran arrière es craque et ne fonctionne plus mais le reste fonctionne très bien,
ma question es ou je peut me procurer un écran PowerShot A540
jmucienko@sympatico.ca
Jocelyn Mucienko - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 24
Her zaman: 1,036
