Ana içeriğe geç
Canon PowerShot A540 Front Cover Replacement
Neye ihtiyacın var
  1. Canon PowerShot A540 Front Cover Replacement, Back Cover: adım 1, 2 resimden 1. Canon PowerShot A540 Front Cover Replacement, Back Cover: adım 1, 2 resimden 2.
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 Front Cover Replacement: adım 2, 1 resimden 1.
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 Front Cover Replacement: adım 3, 1 resimden 1.
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 Front Cover Replacement: adım 4, 1 resimden 1.
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 Front Cover Replacement: adım 5, 3 resimden 1. Canon PowerShot A540 Front Cover Replacement: adım 5, 3 resimden 2. Canon PowerShot A540 Front Cover Replacement: adım 5, 3 resimden 3.
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 Front Cover Replacement, Front Cover: adım 6, 2 resimden 1. Canon PowerShot A540 Front Cover Replacement, Front Cover: adım 6, 2 resimden 2.
    • Turn the camera to view the front.
    • Remove the lens guard.
    • Press the lens guard's button as you turn the guard counterclockwise.
  7. Canon PowerShot A540 Front Cover Replacement: adım 7, 1 resimden 1.
    • Turn the camera to the side left of the LCD screen.
    • Remove the one (1) 4.0 mm screw with the Phillips head #000 screwdriver.
  8. Canon PowerShot A540 Front Cover Replacement: adım 8, 1 resimden 1.
    • Remove the front cover gently.
    • When removing the front cover, a thin, black rubber washer may fall off the lens. If it does, make sure to put it back on the lens before reassembly.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Carley Fuller
434 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S7G12
3 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 1,501
