Giriş
If your camera's function keys are nonresponsive, you may need to replace the function key motherboard. After removing the back cover and the LCD screen, you will be able to replace the function key motherboard yourself.
Neye ihtiyacın var
Turn off the camera.
Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
Turn the camera to view the back.
Remove the one (1) 3.0 mm screw on the top right corner of the screen.
