Ana içeriğe geç
Canon PowerShot A540 LCD Screen Replacement
Neye ihtiyacın var
  1. Canon PowerShot A540 LCD Screen Replacement, Back Cover: adım 1, 2 resimden 1. Canon PowerShot A540 LCD Screen Replacement, Back Cover: adım 1, 2 resimden 2.
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
    FixBot'a Sor
    Yorum Ekle
  2. Canon PowerShot A540 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
    FixBot'a Sor
    Yorum Ekle
  3. Canon PowerShot A540 LCD Screen Replacement: adım 3, 1 resimden 1.
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Canon PowerShot A540 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Canon PowerShot A540 LCD Screen Replacement: adım 5, 3 resimden 1. Canon PowerShot A540 LCD Screen Replacement: adım 5, 3 resimden 2. Canon PowerShot A540 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
    FixBot'a Sor
    Yorum Ekle
  6. Canon PowerShot A540 LCD Screen Replacement, LCD Screen: adım 6, 2 resimden 1. Canon PowerShot A540 LCD Screen Replacement, LCD Screen: adım 6, 2 resimden 2.
    • Turn the camera to view the back.
    • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
    • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
    FixBot'a Sor
    Yorum Ekle
  7. Canon PowerShot A540 LCD Screen Replacement: adım 7, 2 resimden 1. Canon PowerShot A540 LCD Screen Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Lift the LCD Screen off of the back to view the attached ribbon cables.
    • Use tweezers to flip the black bar up.
    FixBot'a Sor
    Yorum Ekle
  8. Canon PowerShot A540 LCD Screen Replacement: adım 8, 3 resimden 1. Canon PowerShot A540 LCD Screen Replacement: adım 8, 3 resimden 2. Canon PowerShot A540 LCD Screen Replacement: adım 8, 3 resimden 3.
    • Gently pull the big ribbon out.
    • Gently pull the small ribbon out.
    • The small ribbon does not have a bar like the big ribbon.
    FixBot'a Sor
    Yorum Ekle
  9. Canon PowerShot A540 LCD Screen Replacement: adım 9, 2 resimden 1. Canon PowerShot A540 LCD Screen Replacement: adım 9, 2 resimden 2.
    • Use tweezers at the top left of the LCD Screen to wedge the top left of the Outer Frame loose.
    • Use your thumb to hold the Outer Frame open.
    • Use the tweezers at the top right of the LCD Screen to wedge the top right of the Outer Frame loose.
    FixBot'a Sor
    Yorum Ekle
  10. Canon PowerShot A540 LCD Screen Replacement: adım 10, 2 resimden 1. Canon PowerShot A540 LCD Screen Replacement: adım 10, 2 resimden 2.
    • Slide the LCD Screen out from the Outer Frame.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Carley Fuller
434 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S7G12
3 Üyeler
20 adet Kılavuz yazıldı
1Rehber Yorum
I wish to purchase a new screen. Where? I feel capable of repair per these instructions and a u tube video.
Geo Schou - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 1,565
