Giriş
If your LCD screen is cracked, broken, unresponsive, or otherwise damaged, you may need to replace it. After removing the back cover, you will have access to the LCD screen to replace it.
Neye ihtiyacın var
Turn off the camera.
Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
Turn the camera to view the back.
Remove the one (1) 3.0 mm screw on the top right corner of the screen.
2 farklı kişi bu kılavuzu tamamladı.
