Ana içeriğe geç
Canon PowerShot A540 SD Card Reader Replacement
Neye ihtiyacın var
  1. Canon PowerShot A540 SD Card Reader Replacement, Back Cover: adım 1, 2 resimden 1. Canon PowerShot A540 SD Card Reader Replacement, Back Cover: adım 1, 2 resimden 2.
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 SD Card Reader Replacement: adım 2, 1 resimden 1.
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 SD Card Reader Replacement: adım 3, 1 resimden 1.
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 SD Card Reader Replacement: adım 4, 1 resimden 1.
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 SD Card Reader Replacement: adım 5, 3 resimden 1. Canon PowerShot A540 SD Card Reader Replacement: adım 5, 3 resimden 2. Canon PowerShot A540 SD Card Reader Replacement: adım 5, 3 resimden 3.
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 SD Card Reader Replacement, SD Card Reader: adım 6, 2 resimden 1. Canon PowerShot A540 SD Card Reader Replacement, SD Card Reader: adım 6, 2 resimden 2.
    • Turn the camera to view the back.
    • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
    • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
  7. Canon PowerShot A540 SD Card Reader Replacement: adım 7, 2 resimden 1. Canon PowerShot A540 SD Card Reader Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift the LCD Screen off of the back to view the attached ribbon cables.
    • Use tweezers to flip the black bar up.
  8. Canon PowerShot A540 SD Card Reader Replacement: adım 8, 3 resimden 1. Canon PowerShot A540 SD Card Reader Replacement: adım 8, 3 resimden 2. Canon PowerShot A540 SD Card Reader Replacement: adım 8, 3 resimden 3.
    • Gently pull the big ribbon out.
    • Gently pull the small ribbon out.
    • The small ribbon does not have a bar like the big ribbon.
  9. Canon PowerShot A540 SD Card Reader Replacement: adım 9, 2 resimden 1. Canon PowerShot A540 SD Card Reader Replacement: adım 9, 2 resimden 2.
    • Remove the two (2) 3.0 mm screws shown with the Phillips head #000 screwdriver.
  10. Canon PowerShot A540 SD Card Reader Replacement: adım 10, 2 resimden 1. Canon PowerShot A540 SD Card Reader Replacement: adım 10, 2 resimden 2.
    • Remove the ribbon from the clamp/bar securing it by using your tweezers to pull the bar up.
  11. Canon PowerShot A540 SD Card Reader Replacement: adım 11, 1 resimden 1.
    • Remove the SD Card reader and replace.
    • There is another metal bar that comes off of the SD Card reader when screws are removed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Cooper Hale
556 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S7G12
3 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 29
Her zaman: 1,214
