Ana içeriğe geç
Canon PowerShot A550 LCD Screen Replacement
Neye ihtiyacın var
  1. Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: adım 1, 3 resimden 1. Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: adım 1, 3 resimden 2. Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: adım 1, 3 resimden 3.
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Canon PowerShot A550 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Canon PowerShot A550 LCD Screen Replacement: adım 3, 1 resimden 1.
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Canon PowerShot A550 LCD Screen Replacement: adım 4, 2 resimden 1. Canon PowerShot A550 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Canon PowerShot A550 LCD Screen Replacement: adım 5, 1 resimden 1.
    • The camera should look like this once the front cover is removed.
  6. Canon PowerShot A550 LCD Screen Replacement: adım 6, 3 resimden 1. Canon PowerShot A550 LCD Screen Replacement: adım 6, 3 resimden 2. Canon PowerShot A550 LCD Screen Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Canon PowerShot A550 LCD Screen Replacement: adım 7, 1 resimden 1.
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. Canon PowerShot A550 LCD Screen Replacement, LCD Screen: adım 8, 1 resimden 1.
    • Use a #00 phillips head screwdriver to remove 2 3.34mm phillips screws holding the LCD screen in place.
  9. Canon PowerShot A550 LCD Screen Replacement: adım 9, 2 resimden 1. Canon PowerShot A550 LCD Screen Replacement: adım 9, 2 resimden 2.
    • Use an iPod Opening Tool to lift the brown portion of the connector to unlock it.
    • Slide the data cable out of the connector.
    • Caution: Do not force the data cable out of the connector. It may rip!
  10. Canon PowerShot A550 LCD Screen Replacement: adım 10, 1 resimden 1.
    • The LCD screen can now be be removed to be fixed/replaced.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Precilla Tang
177 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G6
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 31
Her zaman: 3,715
