Ana içeriğe geç
Canon PowerShot A590 IS Back Cover Replacement
Neye ihtiyacın var
  1. Canon PowerShot A590 IS Back Cover Replacement, Batteries: adım 1, 2 resimden 1. Canon PowerShot A590 IS Back Cover Replacement, Batteries: adım 1, 2 resimden 2.
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
    Can the hatch be replaced. The piece that holds the hatch is broken.
    alisonbforman46 - Yanıt
    I had this issue for some time and never realized that lithium battery was so easily accessible. Fixed my problem.
    Spud Head - Yanıt
  2. Canon PowerShot A590 IS Back Cover Replacement: adım 2, 1 resimden 1.
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Back Cover Replacement: adım 3, 1 resimden 1.
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS Back Cover Replacement, Back Cover: adım 4, 1 resimden 1.
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot A590 IS Back Cover Replacement: adım 5, 1 resimden 1.
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Canon PowerShot A590 IS Back Cover Replacement: adım 6, 1 resimden 1.
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Canon PowerShot A590 IS Back Cover Replacement: adım 7, 1 resimden 1.
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
    Ik kan de achterkant er niet afkrijgen.
    De onderzijde gaat wel wat open, maar wat ik ook probeer de bovenzijde blijft op de een of andere manier haken en geeft geen krimp.
    Hopelijk hooft iemand hier iets op verzonnen om hem wel open te kunnen krijgen.
    mvrgr WH
    W.H. - Yanıt
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Zach
284 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G19
4 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
Alice Reed - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 8,779
