Ana içeriğe geç
Canon PowerShot A590 IS Clock Battery Replacement
Neye ihtiyacın var
    1. Canon PowerShot A590 IS Clock Battery Replacement, Batteries: adım 1, 2 resimden 1. Canon PowerShot A590 IS Clock Battery Replacement, Batteries: adım 1, 2 resimden 2.
      • The battery hatch is on the bottom of the camera.
      • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
      • While the switch is pushed forward, pull the cover away from the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot A590 IS Clock Battery Replacement: adım 2, 1 resimden 1.
      • This camera requires AA batteries.
      • To remove batteries, simply allow them to fall out of the camera.
      • Use a fingernail to lift the clock battery out of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot A590 IS Clock Battery Replacement: adım 3, 1 resimden 1.
      • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot A590 IS Clock Battery Replacement, Locate Clock Battery: adım 4, 1 resimden 1.
      • To access the clock battery, find the clock battery cover, shown here in the red square.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot A590 IS Clock Battery Replacement, Remove Battery Tab: adım 5, 1 resimden 1.
      • When accessing the clock battery, use a fingernail or similar small instrument to gently pull the tab out.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot A590 IS Clock Battery Replacement, Remove Battery from Tab: adım 6, 1 resimden 1.
      • Now that you have the tab and battery removed, use a fingernail or other small tool to remove the battery from the tab.
      • This battery is a CR1220 type watch battery.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot A590 IS Clock Battery Replacement, Replacing Clock Battery: adım 7, 1 resimden 1.
      • When replacing the clock battery, be sure to have the battery oriented properly, as shown in the picture.
      • Remember, the tab goes in with the exposed side of the battery facing towards the lens.
      FixBot'a Sor
      Yorum Ekle
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Matt Wolfe
411 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G19
4 Üyeler
28 adet Kılavuz yazıldı
9Kılavuz Yorumları
thanks its very useful forme
srikrishnan2003 - Yanıt Paylaş
thank you, very useful for my old camera :)
agungsp2000 - Yanıt Paylaş
Perfect! I never even knew I had this battery in there. Couldn't figure out why the date and time wouldn't stay set every time I shut it off. And then I found the answer here.
Thank you very much for the post!
sherlock261 - Yanıt Paylaş
I'm a senior citizen and am not very good with modern technology. Been going crazy trying to set my clock in my digital camera. I didn't want to buy a new one because I have had this one for years (Power Shot A590) and didn't want to have to learn to use a newer one. Finally got smart enough to do a google search for an answer. Will get a new battery tomorrow and solve my problem. Thanks for the help!...the information age is good for something after all.
Pat Solomon - Yanıt Paylaş
Wow this is a great site. I got the answer I needed right away. The instructions were clear, simple and correct. Thank you.
You are bookmarked.
jeffrey wales - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 85
Her zaman: 17,679
