Ana içeriğe geç
Canon PowerShot A590 IS Memory Card Replacement
    1. Canon PowerShot A590 IS Memory Card Replacement, Open the Battery Hatch: adım 1, 1 resimden 1.
      • Be gentle with the hatch, it is fragile.
      • *See battery replacement guide for help opening the hatch.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot A590 IS Memory Card Replacement, Locate Memory Card: adım 2, 1 resimden 1.
      • The memory card slot is shown here in the red rectangle.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot A590 IS Memory Card Replacement, Remove Memory Card: adım 3, 1 resimden 1.
      • To eject your memory card, simply press it into the camera gently, and it will spring out.
      • After it has been released from the camera, just pull it out.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot A590 IS Memory Card Replacement, Replace Memory Card: adım 4, 1 resimden 1.
      • To replace the memory card, make sure it is oriented with the label facing towards the front of the camera, with the contacts going in first, facing the back of the camera.
      • Push the card into the slot gently until you hear a 'click'. It will then be locked into place in the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Zach
284 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G19
4 Üyeler
56 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 46
Her zaman: 6,235
