Giriş
This guide demonstrates how to take off the camera casing and easily pop the broken button back into place.
Neye ihtiyacın var
Remove the three 3 mm screws that attach the side panel to the body of the camera.
Using your fingernails, pull the side panel outward to remove it.
Remove the two remaining 2 mm screws that attach to the frame of the camera.
Remove the back casing.
Flip the casing over and push on the back of the broken button with either your finger or a blunt object until it realigns into its slot.
