Ana içeriğe geç
Canon PowerShot A620 Camera Housing Replacement
Neye ihtiyacın var
  1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: adım 1, 3 resimden 1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: adım 1, 3 resimden 2. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: adım 1, 3 resimden 3.
    • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
  2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: adım 2, 2 resimden 1. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: adım 2, 2 resimden 2.
    • Insert AA batteries according to the diagram printed on the camera.
    • Close the battery door.
  3. Canon PowerShot A620 Camera Housing Replacement, Side Panel: adım 3, 3 resimden 1. Canon PowerShot A620 Camera Housing Replacement, Side Panel: adım 3, 3 resimden 2. Canon PowerShot A620 Camera Housing Replacement, Side Panel: adım 3, 3 resimden 3.
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  4. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: adım 4, 1 resimden 1.
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  5. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: adım 5, 1 resimden 1.
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  6. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: adım 6, 2 resimden 1. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: adım 6, 2 resimden 2.
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  7. Canon PowerShot A620 Camera Housing Replacement, Top Panel: adım 7, 1 resimden 1.
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  8. Canon PowerShot A620 Camera Housing Replacement, Front Panel: adım 8, 2 resimden 1. Canon PowerShot A620 Camera Housing Replacement, Front Panel: adım 8, 2 resimden 2.
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  9. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: adım 9, 2 resimden 1. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: adım 9, 2 resimden 2.
    • Gently pull the terminal cover to separate it from the camera.
  10. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: adım 10, 2 resimden 1. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: adım 10, 2 resimden 2.
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  11. Canon PowerShot A620 Camera Housing Replacement, Back Panel: adım 11, 2 resimden 1. Canon PowerShot A620 Camera Housing Replacement, Back Panel: adım 11, 2 resimden 2.
    • Gently pull the back panel to separate it from the camera.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jaime Abraham
350 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-1, Bruce Fall 2014 CSU Fullerton, Team 1-1, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S1G1
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 1,528
