Ana içeriğe geç
Canon PowerShot A620 Shutter Button Replacement
Neye ihtiyacın var
    1. Canon PowerShot A620 Shutter Button Replacement, Side Panel: adım 1, 3 resimden 1. Canon PowerShot A620 Shutter Button Replacement, Side Panel: adım 1, 3 resimden 2. Canon PowerShot A620 Shutter Button Replacement, Side Panel: adım 1, 3 resimden 3.
      • Unscrew the three Phillips #00 1.6x3mm screws on the side.
      • Lift loose panel from the case.
      • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot A620 Shutter Button Replacement, Bottom Panel: adım 2, 1 resimden 1.
      • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot A620 Shutter Button Replacement, Battery Compartment: adım 3, 1 resimden 1.
      • Open the battery door.
      • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: adım 4, 2 resimden 1. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: adım 4, 2 resimden 2.
      • Lift the terminal cover on the side of the camera.
      • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
      FixBot'a Sor
      Yorum Ekle
    5. Canon PowerShot A620 Shutter Button Replacement, Top Panel: adım 5, 1 resimden 1.
      • Gently pull the top panel to separate it from the case.
      • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    6. Canon PowerShot A620 Shutter Button Replacement, Front Panel: adım 6, 2 resimden 1. Canon PowerShot A620 Shutter Button Replacement, Front Panel: adım 6, 2 resimden 2.
      • Gently pull the front panel to separate it from the camera.
      • The battery terminals are easy to access from this step.
      FixBot'a Sor
      Yorum Ekle
    7. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: adım 7, 2 resimden 1. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: adım 7, 2 resimden 2.
      • Gently pull the terminal cover to separate it from the camera.
      FixBot'a Sor
      Yorum Ekle
    8. Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: adım 8, 2 resimden 1. Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: adım 8, 2 resimden 2.
      • Slide the memory card cover down.
      • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
      FixBot'a Sor
      Yorum Ekle
    9. Canon PowerShot A620 Shutter Button Replacement, Back Panel: adım 9, 2 resimden 1. Canon PowerShot A620 Shutter Button Replacement, Back Panel: adım 9, 2 resimden 2.
      • Gently pull the back panel to separate it from the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: adım 10, 2 resimden 1. Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: adım 10, 2 resimden 2.
      • Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot A620 Shutter Button Replacement, Metal Plate: adım 11, 1 resimden 1.
      • Gently lift the metal plate and move it to the side.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: adım 12, 2 resimden 1. Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: adım 12, 2 resimden 2.
      • Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot A620 Shutter Button Replacement, Trigger Button: adım 13, 1 resimden 1.
      • The trigger button will fall off once the screws have been removed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jaime Abraham
350 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 1-1, Bruce Fall 2014 CSU Fullerton, Team 1-1, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S1G1
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 38
Her zaman: 1,976
