Ana içeriğe geç
Canon PowerShot A630 Battery Door Replacement
Neye ihtiyacın var
  1. Canon PowerShot A630 Battery Door Replacement, Front Panel: adım 1, 2 resimden 1. Canon PowerShot A630 Battery Door Replacement, Front Panel: adım 1, 2 resimden 2.
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Battery Door Replacement: adım 2, 2 resimden 1. Canon PowerShot A630 Battery Door Replacement: adım 2, 2 resimden 2.
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Battery Door Replacement: adım 3, 1 resimden 1.
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Battery Door Replacement: adım 4, 2 resimden 1. Canon PowerShot A630 Battery Door Replacement: adım 4, 2 resimden 2.
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Battery Door Replacement: adım 5, 2 resimden 1. Canon PowerShot A630 Battery Door Replacement: adım 5, 2 resimden 2.
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Battery Door Replacement: adım 6, 1 resimden 1.
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Battery Door Replacement: adım 7, 2 resimden 1. Canon PowerShot A630 Battery Door Replacement: adım 7, 2 resimden 2.
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Battery Door Replacement, Back Panel: adım 8, 2 resimden 1. Canon PowerShot A630 Battery Door Replacement, Back Panel: adım 8, 2 resimden 2.
    • Use the spudger to gently pull back the retaining clip and pull the ribbon out.
    • The top panel should now be completely detached from the camera.
    • Applying too much force to the spudger may damage the retaining clip.
  9. Canon PowerShot A630 Battery Door Replacement: adım 9, 2 resimden 1. Canon PowerShot A630 Battery Door Replacement: adım 9, 2 resimden 2.
    • Remove .2 mm screw using a #00 Philips screwdriver.
    • Gently pry off back panel to remove it.
  10. Canon PowerShot A630 Battery Door Replacement, Battery Door: adım 10, 1 resimden 1.
    • Remover .2 mm screw using a #00 Philips screwdriver.
  11. Canon PowerShot A630 Battery Door Replacement: adım 11, 2 resimden 1. Canon PowerShot A630 Battery Door Replacement: adım 11, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using tweezers, gently pull remove the small rod in the battery door hinge.
  12. Canon PowerShot A630 Battery Door Replacement: adım 12, 2 resimden 1. Canon PowerShot A630 Battery Door Replacement: adım 12, 2 resimden 2.
    • Gently pull up on the battery door to remove it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alicia Burns
645 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G5
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 44
Her zaman: 1,687
