Ana içeriğe geç
Canon PowerShot A630 LCD Screen Replacement
Neye ihtiyacın var
  1. Canon PowerShot A630 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Open the LCD screen of the camera
  2. Canon PowerShot A630 LCD Screen Replacement: adım 2, 2 resimden 1. Canon PowerShot A630 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Rotate the screen so that it is perpendicular to the body of the camera
    • Remove the .2mm screw using a Phillips #00 screwdriver
    • Rotate screen 180 degrees and remove second .2mm screw
  3. Canon PowerShot A630 LCD Screen Replacement: adım 3, 2 resimden 1. Canon PowerShot A630 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Gently remove the back panel of the LCD screen
  4. Canon PowerShot A630 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Once the back panel is removed another .2mm screw will be revealed, remove this screw to remove the front panel of the LCD screen
  5. Canon PowerShot A630 LCD Screen Replacement: adım 5, 1 resimden 1.
    • Gently remove front panel of the LCD screen
  6. Canon PowerShot A630 LCD Screen Replacement: adım 6, 2 resimden 1. Canon PowerShot A630 LCD Screen Replacement: adım 6, 2 resimden 2.
    • Locate the ribbon (orange) and using tweezers gently pull back the retaining clip and pull the ribbon out
  7. Canon PowerShot A630 LCD Screen Replacement: adım 7, 3 resimden 1. Canon PowerShot A630 LCD Screen Replacement: adım 7, 3 resimden 2. Canon PowerShot A630 LCD Screen Replacement: adım 7, 3 resimden 3.
    • Use a spudger to gently remove the LCD screen from the metal backing plate
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kady Rose
198 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G5
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
Where can I purchase a replacement LCD screen?
steigw - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 2,068
