Ana içeriğe geç
Canon PowerShot A630 Shooting Mode Dial Replacement
Neye ihtiyacın var
  1. Canon PowerShot A630 Shooting Mode Dial Replacement, Front Panel: adım 1, 2 resimden 1. Canon PowerShot A630 Shooting Mode Dial Replacement, Front Panel: adım 1, 2 resimden 2.
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 2, 2 resimden 1. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 2, 2 resimden 2.
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 3, 1 resimden 1.
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 4, 2 resimden 1. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 4, 2 resimden 2.
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 5, 2 resimden 1. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 5, 2 resimden 2.
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 6, 1 resimden 1.
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 7, 2 resimden 1. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 7, 2 resimden 2.
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Shooting Mode Dial Replacement, Shooting Mode Dial: adım 8, 2 resimden 1. Canon PowerShot A630 Shooting Mode Dial Replacement, Shooting Mode Dial: adım 8, 2 resimden 2.
    • Pry open the connector on the yellow ribbon cable using a plastic opening tool.
  9. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 9, 1 resimden 1.
    • Remove the 2 mm screws from the metal plate.
  10. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 10, 1 resimden 1.
    • Pull away the metal plate, exposing the underbelly of the mode dial.
    • Be careful not to pull too hard. Metal plate should remain attached.
  11. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 11, 2 resimden 1. Canon PowerShot A630 Shooting Mode Dial Replacement: adım 11, 2 resimden 2.
    • Remove the 2mm screw using the #00 Phillips screwdriver.
    • The mode dial should fall out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alicia Burns
645 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G5
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 614
