Ana içeriğe geç
Canon PowerShot A630 Trigger Button Replacement
Neye ihtiyacın var
  1. Canon PowerShot A630 Trigger Button Replacement, Front Panel: adım 1, 2 resimden 1. Canon PowerShot A630 Trigger Button Replacement, Front Panel: adım 1, 2 resimden 2.
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
    FixBot'a Sor
    Yorum Ekle
  2. Canon PowerShot A630 Trigger Button Replacement: adım 2, 2 resimden 1. Canon PowerShot A630 Trigger Button Replacement: adım 2, 2 resimden 2.
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Canon PowerShot A630 Trigger Button Replacement: adım 3, 1 resimden 1.
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Canon PowerShot A630 Trigger Button Replacement: adım 4, 2 resimden 1. Canon PowerShot A630 Trigger Button Replacement: adım 4, 2 resimden 2.
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Canon PowerShot A630 Trigger Button Replacement: adım 5, 2 resimden 1. Canon PowerShot A630 Trigger Button Replacement: adım 5, 2 resimden 2.
    • Open 'DIGITAL A/V OUT' door on camera.
    FixBot'a Sor
    Yorum Ekle
  6. Canon PowerShot A630 Trigger Button Replacement: adım 6, 1 resimden 1.
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
    FixBot'a Sor
    Yorum Ekle
  7. Canon PowerShot A630 Trigger Button Replacement: adım 7, 2 resimden 1. Canon PowerShot A630 Trigger Button Replacement: adım 7, 2 resimden 2.
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
    FixBot'a Sor
    Yorum Ekle
  8. Canon PowerShot A630 Trigger Button Replacement, Trigger Button: adım 8, 1 resimden 1.
    • Use the spudger to gently pull back the retaining clip and pull the ribbon out
    • The top panel should now be completely detached from the camera
    • Applying to much force to the spudger may damage the retaining clip
    FixBot'a Sor
    Yorum Ekle
  9. Canon PowerShot A630 Trigger Button Replacement: adım 9, 1 resimden 1.
    • Remove the two screws holding down the metal frame using the Phillips #00 screwdriver
    FixBot'a Sor
    Yorum Ekle
  10. Canon PowerShot A630 Trigger Button Replacement: adım 10, 1 resimden 1.
    • Lift up the metal frame to expose the two screws located under the trigger button.
    • Remove the two screws using Phillips #00 screwdriver
    FixBot'a Sor
    Yorum Ekle
  11. Canon PowerShot A630 Trigger Button Replacement: adım 11, 2 resimden 1. Canon PowerShot A630 Trigger Button Replacement: adım 11, 2 resimden 2.
    • Trigger button should fall out
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kelly Duggan
460 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 üyesi
CLEM-BENSON-F14S2G5
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 1,038
