Ana içeriğe geç
Canon PowerShot A75 Batteries Replacement
    1. Canon PowerShot A75 Batteries Replacement, Batteries: adım 1, 1 resimden 1.
      • Turn the camera over and locate the "BATT OPEN" sliding switch.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot A75 Batteries Replacement: adım 2, 3 resimden 1. Canon PowerShot A75 Batteries Replacement: adım 2, 3 resimden 2. Canon PowerShot A75 Batteries Replacement: adım 2, 3 resimden 3.
      • Slide the switch to the right.
      • The battery cover should slide down and spring open.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot A75 Batteries Replacement: adım 3, 3 resimden 1. Canon PowerShot A75 Batteries Replacement: adım 3, 3 resimden 2. Canon PowerShot A75 Batteries Replacement: adım 3, 3 resimden 3.
      • Remove the 4 AA batteries.
      • Watch for the orientation of the batteries as they slide out.
      • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
Ekip
Cal Poly, Team 17-30, Amido Spring 2012 Cal Poly, Team 17-30, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G30
5 Üyeler
18 adet Kılavuz yazıldı
4Kılavuz Yorumları
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
Harry collier - Yanıt Paylaş
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
hot5 - Yanıt Paylaş
Probably you have change backup battery which is rechargeable and not easy to change. It is close to chargeable outlet.
Maganbhai Patel - Yanıt Paylaş
Bonjour j'ai un petit problème avec mon appareil photo. J'essaye de l'ouvrir avec le bouton mais elle ne s'allume pas et les supports de piles ont rouillé et la carte orange à été un peu touché par la rouillé aussi. Comment pourrais-je le faire fonctionner?
Leyla minal - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 67
Her zaman: 3,012
