Ana içeriğe geç
Canon PowerShot A75 Batteries Replacement
  1. Canon PowerShot A75 Batteries Replacement, Batteries: adım 1, 1 resimden 1.
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Batteries Replacement: adım 2, 3 resimden 1. Canon PowerShot A75 Batteries Replacement: adım 2, 3 resimden 2. Canon PowerShot A75 Batteries Replacement: adım 2, 3 resimden 3.
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Batteries Replacement: adım 3, 3 resimden 1. Canon PowerShot A75 Batteries Replacement: adım 3, 3 resimden 2. Canon PowerShot A75 Batteries Replacement: adım 3, 3 resimden 3.
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
Sonuç
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
Henry Braden Fisk
63 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-30, Amido Spring 2012 Cal Poly, Team 17-30, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G30
5 Üyeler
12 adet Kılavuz yazıldı
3Kılavuz Yorumları
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
Harry collier - Yanıt
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
hot5 - Yanıt
Probably you have change backup battery which is rechargeable and not easy to change. It is close to chargeable outlet.
Maganbhai Patel - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 62
Her zaman: 2,286
