Ana içeriğe geç
Canon PowerShot A75 Flash Unit Replacement
Neye ihtiyacın var
  1. Canon PowerShot A75 Flash Unit Replacement, Batteries: adım 1, 1 resimden 1.
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
    FixBot'a Sor
    Yorum Ekle
  2. Canon PowerShot A75 Flash Unit Replacement: adım 2, 3 resimden 1. Canon PowerShot A75 Flash Unit Replacement: adım 2, 3 resimden 2. Canon PowerShot A75 Flash Unit Replacement: adım 2, 3 resimden 3.
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
    FixBot'a Sor
    Yorum Ekle
  3. Canon PowerShot A75 Flash Unit Replacement: adım 3, 3 resimden 1. Canon PowerShot A75 Flash Unit Replacement: adım 3, 3 resimden 2. Canon PowerShot A75 Flash Unit Replacement: adım 3, 3 resimden 3.
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
    FixBot'a Sor
    Yorum Ekle
  4. Canon PowerShot A75 Flash Unit Replacement, Casing: adım 4, 1 resimden 1.
    • Remove the three 2.5mm screws on the bottom of the camera.
    FixBot'a Sor
    Yorum Ekle
  5. Canon PowerShot A75 Flash Unit Replacement: adım 5, 1 resimden 1.
    • Remove the 3.8mm screw underneath the flap that covers the A/V port.
    FixBot'a Sor
    Yorum Ekle
  6. Canon PowerShot A75 Flash Unit Replacement: adım 6, 2 resimden 1. Canon PowerShot A75 Flash Unit Replacement: adım 6, 2 resimden 2.
    • Remove the 2.4mm screw located underneath the cover of the memory card slot.
    FixBot'a Sor
    Yorum Ekle
  7. Canon PowerShot A75 Flash Unit Replacement: adım 7, 2 resimden 1. Canon PowerShot A75 Flash Unit Replacement: adım 7, 2 resimden 2.
    • Open the memory card slot by sliding it laterally until you hear a click.
    • Remove the 5.9mm screw in the upper corner of the memory card slot.
    FixBot'a Sor
    Yorum Ekle
  8. Canon PowerShot A75 Flash Unit Replacement: adım 8, 1 resimden 1.
    • Remove the two 4.1mm screws at the bottom of the battery flap.
    FixBot'a Sor
    Yorum Ekle
  9. Canon PowerShot A75 Flash Unit Replacement: adım 9, 2 resimden 1. Canon PowerShot A75 Flash Unit Replacement: adım 9, 2 resimden 2.
    • Lift the shutter button and speaker part from the top of the camera.
    • DO NOT pull the part too hard because there is a plug connecting the speaker to the camera.
    FixBot'a Sor
    Yorum Ekle
  10. Canon PowerShot A75 Flash Unit Replacement: adım 10, 3 resimden 1. Canon PowerShot A75 Flash Unit Replacement: adım 10, 3 resimden 2. Canon PowerShot A75 Flash Unit Replacement: adım 10, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
    FixBot'a Sor
    Yorum Ekle
  11. Canon PowerShot A75 Flash Unit Replacement: adım 11, 1 resimden 1.
    • Remove the rightmost 4.2mm screw underneath the battery cover, not the center screw.
    FixBot'a Sor
    Yorum Ekle
  12. Canon PowerShot A75 Flash Unit Replacement: adım 12, 3 resimden 1. Canon PowerShot A75 Flash Unit Replacement: adım 12, 3 resimden 2. Canon PowerShot A75 Flash Unit Replacement: adım 12, 3 resimden 3.
    • Separate the back casing and front casing of the camera using your hands.
    • Pulling the two halves apart can be difficult, especially at the top. Use a moderate amount of force.
    FixBot'a Sor
    Yorum Ekle
  13. Canon PowerShot A75 Flash Unit Replacement: adım 13, 3 resimden 1. Canon PowerShot A75 Flash Unit Replacement: adım 13, 3 resimden 2. Canon PowerShot A75 Flash Unit Replacement: adım 13, 3 resimden 3.
    • On the front of the camera, press the button on the lower left of the lens.
    • Twist the outer lens casing counter-clockwise and slide it out.
    FixBot'a Sor
    Yorum Ekle
  14. Canon PowerShot A75 Flash Unit Replacement: adım 14, 3 resimden 1. Canon PowerShot A75 Flash Unit Replacement: adım 14, 3 resimden 2. Canon PowerShot A75 Flash Unit Replacement: adım 14, 3 resimden 3.
    • Take off the front casing.
    • There is a black rubber washer around the lens that comes out after you take the casing off. Make sure to replace it when putting the camera back together.
    FixBot'a Sor
    Yorum Ekle
  15. Canon PowerShot A75 Flash Unit Replacement, Flash Unit: adım 15, 3 resimden 1. Canon PowerShot A75 Flash Unit Replacement, Flash Unit: adım 15, 3 resimden 2. Canon PowerShot A75 Flash Unit Replacement, Flash Unit: adım 15, 3 resimden 3.
    • Rotate the camera such that the flash unit and capacitor are facing you.
    • DO NOT touch the capacitor because it may shock you.
    • Remove the 3.5mm screw located between the flash unit and the capacitor.
    FixBot'a Sor
    Yorum Ekle
  16. Canon PowerShot A75 Flash Unit Replacement: adım 16, 2 resimden 1. Canon PowerShot A75 Flash Unit Replacement: adım 16, 2 resimden 2.
    • Snap flash unit out of place with your fingers.
    • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
    • Unsolder the five wires connected to the flash unit in order to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Chris Miyahira
38 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-30, Amido Spring 2012 Cal Poly, Team 17-30, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G30
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 23
Her zaman: 1,216
