Ana içeriğe geç
Canon PowerShot A75 Speaker Replacement
Neye ihtiyacın var
  1. Canon PowerShot A75 Speaker Replacement, Batteries: adım 1, 1 resimden 1.
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Speaker Replacement: adım 2, 3 resimden 1. Canon PowerShot A75 Speaker Replacement: adım 2, 3 resimden 2. Canon PowerShot A75 Speaker Replacement: adım 2, 3 resimden 3.
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Speaker Replacement: adım 3, 3 resimden 1. Canon PowerShot A75 Speaker Replacement: adım 3, 3 resimden 2. Canon PowerShot A75 Speaker Replacement: adım 3, 3 resimden 3.
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. Canon PowerShot A75 Speaker Replacement, Speaker: adım 4, 2 resimden 1. Canon PowerShot A75 Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Open the memory card slot by sliding it laterally until you hear a click
    • Remove the 5.9mm screw in the upper corner of the memory card slot
  5. Canon PowerShot A75 Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  6. Canon PowerShot A75 Speaker Replacement: adım 6, 2 resimden 1. Canon PowerShot A75 Speaker Replacement: adım 6, 2 resimden 2.
    • Lift the shutter button and speaker part from the top of the camera.
    • Do not pull the part too hard because there is a plug connecting the speaker to the camera.
  7. Canon PowerShot A75 Speaker Replacement: adım 7, 3 resimden 1. Canon PowerShot A75 Speaker Replacement: adım 7, 3 resimden 2. Canon PowerShot A75 Speaker Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  8. Canon PowerShot A75 Speaker Replacement: adım 8, 1 resimden 1.
    • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
    • Remove the glue and unsolder the speaker from the outer casing. Replace or repair the speaker as necessary.
Sonuç
Austin Fox
1 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-30, Amido Spring 2012 Cal Poly, Team 17-30, Amido Spring 2012 üyesi
CPSU-AMIDO-S12S17G30
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 18
Her zaman: 439
