Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The flash assembly is a retractable light bulb fixture that displays a quick burst of background light emited from a light bulb.
Neye ihtiyacın var
Using a Phillips #00 screwdriver, remove the 3.3 mm long top screw located on the side of the camera. This screw holds the side panels and the front cover together.
To reassemble your device, follow these instructions in reverse order. Remember to re-solder any wires that were unsoldered.
Bir başkası bu kılavuzu tamamladı.
