Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the three Phillips #00 screws from the bottom of the camera.
Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open.
Remove the memory card if it is still in the camera.
Use the Phillips #00 screwdriver to remove the single screw underneath the memory card slot door.
Remove the Phillips #00 screw located inside the top of the memory card compartment.
Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down.
Remove the batteries from the compartment.
Remove the three Phillips #00 screws located inside the battery compartment.
Remove the top lid of the camera.
The door to the memory card compartment will be freed and should be removable now.
Remove the two Phillips #00 screws from the side of the camera.
Open the small rubber door below this screw that covers the connectors.
Open and pivot the LCD screen to its widest open position.
Remove the rear cover by pulling it straight away from the body of the camera.
Using a Phillips #00 screwdriver, remove the 3.3 mm long top screw located on the side of the camera. This screw holds the side panels and the front cover together.
Gently remove the side panel by pulling it away from the camera.
Using the Phillips #00 screwdriver, unscrew the 2.4 mm long screw that holds on the front panel underneath the side panel.
Underneath the battery cover there is a 3.8 mm screw in the corner. Using the Phillips #00 screwdriver, remove this screw.
Gently pull up on the front cover to remove it from the body.
