Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
To isolate the LCD screen, one needs to be gentle with separating parts and removing screws from the camera.
Parçalar
Hiçbir parça belirtilmedi.
  1. Unscrew the two 2.9 mm screws on the side of the screen that connect the front and back cover of the LCD screen. Use a #00 screwdriver.
    • Unscrew the two 2.9 mm screws on the side of the screen that connect the front and back cover of the LCD screen. Use a #00 screwdriver.
  2. Unscrew the 2.9 mm side screws on the other side of the screen using the #00 screwdriver. These also hold the screen covers together. To get to the second screw, rotate the screen.
    • Unscrew the 2.9 mm side screws on the other side of the screen using the #00 screwdriver. These also hold the screen covers together.
    • To get to the second screw, rotate the screen.
  3. LCD iPhone Ekran Tamir Kit'leri
    Ömür Boyu Garantimiz kapsamındaki bütçe seçeneği.
    Shop Kits
    Onarım maliyetlerini düşürün, kaliteyi değil.
    Shop Kits
  4. Gently peel off the front and back cover of the screen. Peel back the plastic cover. Peel back the plastic cover.
    • Gently peel off the front and back cover of the screen.
    • Peel back the plastic cover.
  5. Gently pull off the screen from the base.
    • Gently pull off the screen from the base.
    • A small metal piece between the screen cover and the screen may fall out during repair. Remember to replace it with the rounded corners facing away from the screen during reassembly.
    • This takes a little force.
  6. Unplug the wires that are attaching the screen to the circuit board.
    • Unplug the wires that are attaching the screen to the circuit board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
konrad
217 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 7-31, Regan Winter 2011 Cal Poly, Team 7-31, Regan Winter 2011 üyesi
CPSU-REGAN-W11S7G31
6 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
MY screen is dark after touched water, do I need to change this screen? Where can I buy this screen? How much?
Thank you for the guidance.
jennifer
yu123xi@yahoo.com
yu123xi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 3,413
