Ana içeriğe geç
Canon PowerShot ELPH 300HS Power Button Replacement
Neye ihtiyacın var
    • Before you begin taking apart your device, the first, and MOST IMPORTANT STEPS are to:
    • Turn off your camera.
    • Remove the battery to prevent risk of shock.
  1. Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Battery: adım 2, 2 resimden 1. Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Battery: adım 2, 2 resimden 2.
    • Turn off your camera by pressing the power button, located on the top-center of the device.
    • Locate the battery door on the bottom right area of the camera case.
    • Place your finger firmly on the black rubber pad on the battery door and slide the door to the right to open it.
    • Locate the orange battery release button beneath the battery door.
    • Slide the battery release button downward to release the battery.
  2. Canon PowerShot ELPH 300HS Power Button Replacement, Left Side Screws: adım 3, 1 resimden 1.
    • Be careful when removing screws, as they are stripped easily.
    • Remove the two screws located on the left side of the camera case, using the Phillips screwdriver #00 (2.0 mm).
  3. Canon PowerShot ELPH 300HS Power Button Replacement, Bottom Screws: adım 4, 1 resimden 1.
    • Remove the two screws on the bottom of the camera located near the battery door (Phillips #00 screwdriver) (4.0 mm).
  4. Canon PowerShot ELPH 300HS Power Button Replacement, Right Side Screws: adım 5, 1 resimden 1.
    • Remove the screw located on the lower right side of the camera case (Phillips #00 screwdriver) (4.0 mm).
    • Remove the HDMI A/V out port cover located on the upper right side of the camera.
    • Remove the screw located just beneath the port cover removed in step 2. (Phillips #00 screwdriver) (2.0 mm).
  5. Canon PowerShot ELPH 300HS Power Button Replacement: adım 6, 1 resimden 1.
    • Remove the back portion of the camera case to reveal the screw located on the top of the case.
    • Remove the screw from the top of camera case, located next to the shutter button (Phillips #00 screwdriver) (1.5 mm).
  6. Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Case from the Camera: adım 7, 3 resimden 1. Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Case from the Camera: adım 7, 3 resimden 2. Canon PowerShot ELPH 300HS Power Button Replacement, Remove the Case from the Camera: adım 7, 3 resimden 3.
    • Carefully pry the case apart at the seem, using your fingers.
    • Be careful not to over bend the small metal projections located along the seams. These aid in holding the case together.
    • Be careful not to allow dust or other particles to settle inside of the camera while the case is detached. This can cause functional issues in the future.
  7. Canon PowerShot ELPH 300HS Power Button Replacement, Power Button: adım 8, 2 resimden 1. Canon PowerShot ELPH 300HS Power Button Replacement, Power Button: adım 8, 2 resimden 2.
    • Disconnect the small cable from the yellow port on the motherboard
  8. Canon PowerShot ELPH 300HS Power Button Replacement: adım 9, 1 resimden 1.
    • Disconnect the small cable from the blue port on the motherboard
  9. Canon PowerShot ELPH 300HS Power Button Replacement: adım 10, 1 resimden 1.
    • Lift the plastic over the HDMI port on the side of the camera
  10. Canon PowerShot ELPH 300HS Power Button Replacement: adım 11, 2 resimden 1. Canon PowerShot ELPH 300HS Power Button Replacement: adım 11, 2 resimden 2.
    • Lift from the back of the camera, angling forward and pull off to remove the power button assembly
Sonuç
Kathryn Van Susante
697 İtibar
5 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 5-6, Lauer Spring 2014 Michigan Tech, Team 5-6, Lauer Spring 2014 üyesi
MTU-LAUER-S14S5G6
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 28
Her zaman: 2,398
