Ana içeriğe geç
Canon PowerShot ELPH 310 HS LCD Screen Replacement
Neye ihtiyacın var
  1. Canon PowerShot ELPH 310 HS LCD Screen Replacement, External Panels: adım 1, 1 resimden 1.
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 2, 2 resimden 1. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 2, 2 resimden 2.
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 3, 2 resimden 1. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 3, 2 resimden 2.
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 4, 2 resimden 1. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 4, 2 resimden 2.
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 5, 1 resimden 1.
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 6, 2 resimden 1. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 6, 2 resimden 2.
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 7, 1 resimden 1.
    • Manually remove the front panel from the camera.
  8. Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: adım 8, 2 resimden 1. Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: adım 8, 2 resimden 2.
    • Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
  9. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 9, 1 resimden 1.
    • Using your hands, lift up the screen.
    • The screen is fragile!
  10. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 10, 3 resimden 1. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 10, 3 resimden 2. Canon PowerShot ELPH 310 HS LCD Screen Replacement: adım 10, 3 resimden 3.
    • The strip tears easily!
    • Manually lift the shutter button plate and remove the white ZIF connector, which is the white clasp underneath.
    • On the front of the camera, using your fingers, undo the orange ribbon from the gray clasp and pull the ribbon through the shutter deck.
Sonuç
Kadie Aldridge
213 İtibar
2 adet Kılavuz yazıldı
1Rehber Yorum
Part number for the screen replacement
Jeff Herider - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,281
