Ana içeriğe geç
Canon PowerShot ELPH330 HS Camera Case Replacement
Neye ihtiyacın var
  1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: adım 1, 2 resimden 1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: adım 1, 2 resimden 2.
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right which will then open the door.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Case Replacement: adım 2, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the two screws.
  3. Canon PowerShot ELPH330 HS Camera Case Replacement: adım 3, 1 resimden 1.
    • Remove two more screws using the Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Case Replacement: adım 4, 1 resimden 1.
    • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
    • On the upper right side of the camera, remove the HDMI A/V out port.
    • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Case Replacement: adım 5, 1 resimden 1.
    • Using your fingers, carefully pry the case apart at the seam.
Sonuç
Michelle Ngo
595 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G3, Liner Summer 2019 UW Tacoma, Team S1-G3, Liner Summer 2019 üyesi
UWT-LINER-SU19S1G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 177
