Ana içeriğe geç
Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement
Neye ihtiyacın var
  1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: adım 1, 2 resimden 1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: adım 1, 2 resimden 2.
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right to open it.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: adım 2, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the screws.
  3. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: adım 3, 1 resimden 1.
    • Remove the two 4.0mm screws on the bottom of the camera located near the battery door using a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: adım 4, 1 resimden 1.
    • At the bottom of the camera next to the battery door, remove two more screws using the Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: adım 5, 1 resimden 1.
    • To remove the back portion of the camera case, use your fingers to carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: adım 6, 2 resimden 1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: adım 6, 2 resimden 2.
    • On the motherboard there should be a white port. Using the spudger, disconnect it from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: adım 7, 1 resimden 1.
    • Follow the green and white wire. There is a gray piece of rubber holding the button into place. Remove it with the spudger.
  8. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: adım 8, 1 resimden 1.
    • Lift the panel off from the top of the camera with your hands.
Sonuç
Michelle Ngo
595 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G3, Liner Summer 2019 UW Tacoma, Team S1-G3, Liner Summer 2019 üyesi
UWT-LINER-SU19S1G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 521
