Ana içeriğe geç
Canon PowerShot G1 X Battery Replacement
  1. Canon PowerShot G1 X Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Pull the switch on the back of the battery case back towards the open arrow to release a latch.
    • The lid should pop open revealing the battery and a small red switch holding the battery in place.
  2. Canon PowerShot G1 X Battery Replacement: adım 2, 2 resimden 1. Canon PowerShot G1 X Battery Replacement: adım 2, 2 resimden 2.
    • To release the battery, gently push the switch off the top of the battery and pull the battery out of the casing.
    • Place the new battery in the casing with the four metal connections (small squares on the bottom of the battery)in the bottom right hand corner of the bottom of the camera. If you look inside the casing you will see where the connections will meet. This will give you more of an idea on the orientation of the battery.
Sonuç
Cleston Sanders
124 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 20-1, Remmell Spring 2017 USF Tampa, Team 20-1, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S20G1
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 423
