Giriş
This guide shows how to replace the lens of your camera. This replacement would be necessary if the lens of your camera has a scratch on it or if your camera is not taking pictures properly due to faulty connections from the lens to the internal components of your camera.
Neye ihtiyacın var
Locate the battery housing cover on the bottom of your camera.
Place a finger on the textured portion of the battery housing cover.
Slide the cover in the direction that the arrow is pointing.
Remove the two 4mm Hex screws that connect the grip to the camera with a Hex head screwdriver.
Remove the two Phillips screws to the left of the hex screws with a Phillips head screwdriver:
One 2mm screw
One 3mm screw
Remove the grip from the front of the camera by pulling it away from the lens and then away from the camera.
Use the flat end of the plastic spudger to rotate the black plastic locking tab towards the ribbon cable.
Insert the pointed end of the plastic spudger into a small hole on the side of the ribbon cable and pull the ribbon cable out of its housing.
Use the flat end of the plastic spudger to pry the ribbon cable connector from the motherboard.
Bu adımda kullanılan alet:Tweezers$4.99
Release the plastic locking tab of the upper ribbon cable with the plastic spudger.
Pull the top ribbon cable from its mount with the fine tip metal tweezers.
Remove the bottom ribbon cable with the fine tip metal tweezers by pulling it toward the flash switch side of the camera.
Use the plastic spudger to remove the ribbon cable from the motherboard by placing the spudger under the ribbon cable connector and pulling up.
Remove the 2.8mm screw from the motherboard.
Carefully rotate the motherboard upward.
Use the plastic spudger to remove the ribbon cable from the bottom of the motherboard by placing the spudger under the ribbon cable connector and pulling up.
Remove the four 4.25mm Philips screws from the silver frame that surrounds the lens of the camera with a Philips Head screwdriver.
Remove the frame by lifting straight up.
4 farklı kişi bu kılavuzu tamamladı.
