Ana içeriğe geç
Canon PowerShot G11 Front Cover Replacement
Neye ihtiyacın var
  1. Canon PowerShot G11 Front Cover Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
    FixBot'a Sor
    Yorum Ekle
  2. Canon PowerShot G11 Front Cover Replacement: adım 2, 1 resimden 1.
    • Remove the four screws on the left side of the camera.
    FixBot'a Sor
    Yorum Ekle
  3. Canon PowerShot G11 Front Cover Replacement: adım 3, 1 resimden 1.
    • Remove the screw on the right side of the camera.
    FixBot'a Sor
    Yorum Ekle
  4. Canon PowerShot G11 Front Cover Replacement: adım 4, 1 resimden 1.
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
    FixBot'a Sor
    Yorum Ekle
  5. Canon PowerShot G11 Front Cover Replacement: adım 5, 1 resimden 1.
    • Remove the screw to the right of the view finder on the rear of the camera.
    FixBot'a Sor
    Yorum Ekle
  6. Canon PowerShot G11 Front Cover Replacement: adım 6, 1 resimden 1.
    • Use the spudger to crack open the case.
    FixBot'a Sor
    Yorum Ekle
  7. Canon PowerShot G11 Front Cover Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
    FixBot'a Sor
    Yorum Ekle
  8. Canon PowerShot G11 Front Cover Replacement: adım 8, 1 resimden 1.
    • The rear cover is now unattached from the camera.
    FixBot'a Sor
    Yorum Ekle
  9. Canon PowerShot G11 Front Cover Replacement, Front Cover: adım 9, 2 resimden 1. Canon PowerShot G11 Front Cover Replacement, Front Cover: adım 9, 2 resimden 2.
    • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
    FixBot'a Sor
    Yorum Ekle
  10. Canon PowerShot G11 Front Cover Replacement: adım 10, 1 resimden 1.
    • Use the spudger to pop off front case.
    FixBot'a Sor
    Yorum Ekle
  11. Canon PowerShot G11 Front Cover Replacement: adım 11, 1 resimden 1.
    • Pull the loosened cover off and you are finished.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dustin Brinegar
715 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G6
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 37
Her zaman: 2,866
