Ana içeriğe geç
Canon PowerShot G11 Front Cover Replacement
Neye ihtiyacın var
  1. Canon PowerShot G11 Front Cover Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Front Cover Replacement: adım 2, 1 resimden 1.
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Front Cover Replacement: adım 3, 1 resimden 1.
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Front Cover Replacement: adım 4, 1 resimden 1.
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Front Cover Replacement: adım 5, 1 resimden 1.
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Front Cover Replacement: adım 6, 1 resimden 1.
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Front Cover Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Front Cover Replacement: adım 8, 1 resimden 1.
    • The rear cover is now unattached from the camera.
  9. Canon PowerShot G11 Front Cover Replacement, Front Cover: adım 9, 2 resimden 1. Canon PowerShot G11 Front Cover Replacement, Front Cover: adım 9, 2 resimden 2.
    • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
  10. Canon PowerShot G11 Front Cover Replacement: adım 10, 1 resimden 1.
    • Use the spudger to pop off front case.
  11. Canon PowerShot G11 Front Cover Replacement: adım 11, 1 resimden 1.
    • Pull the loosened cover off and you are finished.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dustin Brinegar
688 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G6
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 2,417
