Ana içeriğe geç
Canon PowerShot G11 Rear Dial Replacement
Neye ihtiyacın var
    1. Canon PowerShot G11 Rear Dial Replacement, Rear Cover: adım 1, 1 resimden 1.
      • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot G11 Rear Dial Replacement: adım 2, 1 resimden 1.
      • Remove the four screws on the left side of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot G11 Rear Dial Replacement: adım 3, 1 resimden 1.
      • Remove the screw on the right side of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot G11 Rear Dial Replacement: adım 4, 1 resimden 1.
      • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
      FixBot'a Sor
      Yorum Ekle
    5. Canon PowerShot G11 Rear Dial Replacement: adım 5, 1 resimden 1.
      • Remove the screw to the right of the view finder on the rear of the camera.
      FixBot'a Sor
      Yorum Ekle
    6. Canon PowerShot G11 Rear Dial Replacement: adım 6, 1 resimden 1.
      • Use the spudger to crack open the case.
      FixBot'a Sor
      Yorum Ekle
    7. Canon PowerShot G11 Rear Dial Replacement: adım 7, 1 resimden 1.
      Bu adımda kullanılan alet:
      • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
      FixBot'a Sor
      Yorum Ekle
    8. Canon PowerShot G11 Rear Dial Replacement: adım 8, 1 resimden 1.
      • The rear cover is now unattached from the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot G11 Rear Dial Replacement, Rear Dial: adım 9, 1 resimden 1.
      • Remove the plastic covering of the left side of the rear case interior.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot G11 Rear Dial Replacement: adım 10, 1 resimden 1.
      • Remove the four screws that are now accessible with the removal of the plastic covering them.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot G11 Rear Dial Replacement: adım 11, 2 resimden 1. Canon PowerShot G11 Rear Dial Replacement: adım 11, 2 resimden 2.
      • After the screws are removed, pull the metal bracket out of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot G11 Rear Dial Replacement: adım 12, 1 resimden 1.
      • Push the dial out from the other side of the cover.
      FixBot'a Sor
      Yorum Ekle
    5. Canon PowerShot G11 Rear Dial Replacement: adım 13, 1 resimden 1.
      • Remove the dial from the case completely.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dustin Brinegar
715 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G6
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 41
Her zaman: 2,737
