Ana içeriğe geç
Canon PowerShot G11 Rear Dial Replacement
Neye ihtiyacın var
  1. Canon PowerShot G11 Rear Dial Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Rear Dial Replacement: adım 2, 1 resimden 1.
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Rear Dial Replacement: adım 3, 1 resimden 1.
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Rear Dial Replacement: adım 4, 1 resimden 1.
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Rear Dial Replacement: adım 5, 1 resimden 1.
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Rear Dial Replacement: adım 6, 1 resimden 1.
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Rear Dial Replacement: adım 7, 1 resimden 1.
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Rear Dial Replacement: adım 8, 1 resimden 1.
    • The rear cover is now unattached from the camera.
  9. Canon PowerShot G11 Rear Dial Replacement, Rear Dial: adım 9, 1 resimden 1.
    • Remove the plastic covering of the left side of the rear case interior.
  10. Canon PowerShot G11 Rear Dial Replacement: adım 10, 1 resimden 1.
    • Remove the four screws that are now accessible with the removal of the plastic covering them.
  11. Canon PowerShot G11 Rear Dial Replacement: adım 11, 2 resimden 1. Canon PowerShot G11 Rear Dial Replacement: adım 11, 2 resimden 2.
    • After the screws are removed, pull the metal bracket out of the camera.
  12. Canon PowerShot G11 Rear Dial Replacement: adım 12, 1 resimden 1.
    • Push the dial out from the other side of the cover.
  13. Canon PowerShot G11 Rear Dial Replacement: adım 13, 1 resimden 1.
    • Remove the dial from the case completely.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Dustin Brinegar
688 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G6
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 2,124
