Ana içeriğe geç
Canon PowerShot G11 Top Cover Replacement
Neye ihtiyacın var
    1. Canon PowerShot G11 Top Cover Replacement, Front Cover: adım 1, 2 resimden 1. Canon PowerShot G11 Top Cover Replacement, Front Cover: adım 1, 2 resimden 2.
      • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot G11 Top Cover Replacement: adım 2, 1 resimden 1.
      • Use the spudger to pop off front case.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot G11 Top Cover Replacement: adım 3, 1 resimden 1.
      • Pull the loosened cover off and you are finished.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PowerShot G11 Top Cover Replacement, Top Cover: adım 4, 1 resimden 1.
      • Once both the front and rear covers are removed, disconnect this ribbon cable by flipping it up and disconnecting it.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PowerShot G11 Top Cover Replacement: adım 5, 1 resimden 1.
      • Remove these three screws from the rear side of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PowerShot G11 Top Cover Replacement: adım 6, 1 resimden 1.
      • Remove this screw from the front of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PowerShot G11 Top Cover Replacement: adım 7, 1 resimden 1.
      • Disconnect this cable from the motherboard by sliding it in the direction of the cable (toward the top of the camera).
      FixBot'a Sor
      Yorum Ekle
    5. Canon PowerShot G11 Top Cover Replacement: adım 8, 1 resimden 1.
      • Remove the top cover and you are finished.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dustin Brinegar
715 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G6
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
In step 5, it is only necessary to take out the 2 SST screws at ~ 10 and 3 o’clock. The grey screw at 7 stays with the body.
In step 7, you need to SLIDE the connector toward the top of the camera toward the dial. The tweezers in the photo are moving LEFT, not toward the viewer as I interpreted it. If you lift it up as if to disconnect a socket (like in step 4) away from the mother board with tweezers, you’ll easily destroy the delicate connector (as I found out).
Dimwit - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 2,078
