Ana içeriğe geç
Canon PowerShot G3 Flash Capacitor Replacement
Neye ihtiyacın var
  1. Canon PowerShot G3 Flash Capacitor Replacement, Flash Capacitor: adım 1, 1 resimden 1.
    • Start to remove all of the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Flash Capacitor Replacement: adım 2, 1 resimden 1.
    • Once the screws have been removed, Remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Flash Capacitor Replacement: adım 3, 1 resimden 1.
    • Next remove the front panel and right side panels (the left side is part of the front).
  4. Canon PowerShot G3 Flash Capacitor Replacement: adım 4, 1 resimden 1.
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Flash Capacitor Replacement: adım 5, 2 resimden 1. Canon PowerShot G3 Flash Capacitor Replacement: adım 5, 2 resimden 2.
    • The front of camera should now resemble the picture shown.
    • To remove the circuit ribbon (the brown strips) pull them out of the plastic pieces they are connected to.
  6. Canon PowerShot G3 Flash Capacitor Replacement: adım 6, 1 resimden 1.
    • After that you can lift up the capacitor housing by using your finger nail, or other small object, to lift it up around the edges.
  7. Canon PowerShot G3 Flash Capacitor Replacement: adım 7, 2 resimden 1. Canon PowerShot G3 Flash Capacitor Replacement: adım 7, 2 resimden 2.
    • Use a spudger, or other thin object, to remove the capacitor from the housing. (Image 2)
    • To remove the red and yellow wires connected to the capacitor, use a soldering iron to heat up the solder and a vacuum to suck up the solder. Any other methods you know of will also work.
    • Take the capacitor to you local electronics store or order another capacitor online by reading the capacity off of the side of the capacitor. It should be in microFarads (µF).
    • Once you have a new capacitor, solder on the red and yellow wires to the same place as the old capacitor.
Sonuç
Ryan Riales
201 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Better discharge that cap,so you don't suffer a 250V shock.
Jon Jensen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 646
