Giriş
Replacing the screen on a Canon PowerShot G3 is a process that takes a few steps, but are all simple. If the screen is cracked, displaying odd images, or will not turn on, it will need to be replaced. No special skills are required to replace the screen, but keep in mind attention to detail and a gentle hand are important. Follow this guide to replace the screen of a Canon Powershot G3.
Neye ihtiyacın var
On the bottom of the camera, push and slide open the battery compartment.
Remove the battery.
Repeat Steps 1-7 in reverse order to reassemble.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I'm guessing that the screen is OK and the wiring/connections is the problem.
