Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will teach you how to replace the screen on a Canon PowerShot G3.
Neye ihtiyacın var
On the bottom of the camera, push and slide open the battery compartment.
Remove the battery.
Replace back panel. Make sure the metal part of the panel goes under the metal part of the rotating arm or the screw won't go in.
Put the four screws back in from step 2 and 3 respectively.
Step 2 screws go in the outside of the panel. Step 3 screws go in on the underside of the panel.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
I'm guessing that the screen is OK and the wiring/connections is the problem.
