Ana içeriğe geç
Canon PowerShot G3 Speaker Replacement
Neye ihtiyacın var
  1. Canon PowerShot G3 Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Start to remove the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Speaker Replacement: adım 2, 1 resimden 1.
    • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Speaker Replacement: adım 3, 1 resimden 1.
    • Next remove the front and right side panels (the left is attached to the front panel).
  4. Canon PowerShot G3 Speaker Replacement: adım 4, 1 resimden 1.
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Speaker Replacement: adım 5, 2 resimden 1. Canon PowerShot G3 Speaker Replacement: adım 5, 2 resimden 2.
    • The front of the camera should now resemble the picture shown. (Image 1)
    • Remove the capacitor/speaker housing using your finger nail or other thin object to lift it up around the edges. (Image 2)
  6. Canon PowerShot G3 Speaker Replacement: adım 6, 1 resimden 1.
    • To remove the circuit ribbon (brown strip) pull it out of the plastic piece it is connected to.
  7. Canon PowerShot G3 Speaker Replacement: adım 7, 1 resimden 1.
    • You should now be able to see how the capacitor/speaker housing slides out of the frame.
  8. Canon PowerShot G3 Speaker Replacement: adım 8, 2 resimden 1. Canon PowerShot G3 Speaker Replacement: adım 8, 2 resimden 2.
    • Disconnect the speaker wires from the camera, then use a small flat head screw driver to lift the speaker out of its housing.
    • Order a new speaker from the manufacturer or take it to a local electronics store to see if they have one.
Sonuç
Ryan Riales
201 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 244
