Ana içeriğe geç
Canon PowerShot G7X Dial Replacement
Neye ihtiyacın var
  1. Canon PowerShot G7X Dial Replacement, Dial: adım 1, 1 resimden 1.
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Dial Replacement: adım 2, 1 resimden 1.
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Dial Replacement: adım 3, 1 resimden 1.
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Dial Replacement: adım 4, 1 resimden 1.
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Dial Replacement: adım 5, 1 resimden 1.
    • Remove the back plate.
  6. Canon PowerShot G7X Dial Replacement: adım 6, 1 resimden 1.
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Dial Replacement: adım 7, 2 resimden 1. Canon PowerShot G7X Dial Replacement: adım 7, 2 resimden 2.
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
Sonuç
McKenzie Devlin
195 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 540
