Ana içeriğe geç
Canon PowerShot G7X Motherboard Replacement
Neye ihtiyacın var
  1. Canon PowerShot G7X Motherboard Replacement, Dial: adım 1, 1 resimden 1.
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the back plate.
  6. Canon PowerShot G7X Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Motherboard Replacement: adım 7, 2 resimden 1. Canon PowerShot G7X Motherboard Replacement: adım 7, 2 resimden 2.
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Motherboard Replacement, Flash: adım 8, 2 resimden 1. Canon PowerShot G7X Motherboard Replacement, Flash: adım 8, 2 resimden 2.
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Motherboard Replacement: adım 9, 2 resimden 1. Canon PowerShot G7X Motherboard Replacement: adım 9, 2 resimden 2.
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Motherboard Replacement: adım 10, 2 resimden 1. Canon PowerShot G7X Motherboard Replacement: adım 10, 2 resimden 2.
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Motherboard Replacement: adım 11, 2 resimden 1. Canon PowerShot G7X Motherboard Replacement: adım 11, 2 resimden 2.
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Motherboard Replacement: adım 12, 1 resimden 1.
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Motherboard Replacement: adım 13, 2 resimden 1. Canon PowerShot G7X Motherboard Replacement: adım 13, 2 resimden 2.
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Motherboard Replacement: adım 14, 2 resimden 1. Canon PowerShot G7X Motherboard Replacement: adım 14, 2 resimden 2.
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Motherboard Replacement: adım 15, 2 resimden 1. Canon PowerShot G7X Motherboard Replacement: adım 15, 2 resimden 2.
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
  16. Canon PowerShot G7X Motherboard Replacement, Lens: adım 16, 1 resimden 1.
    • Remove the 5 mm Phillips #000 screw from the copper plate.
  17. Canon PowerShot G7X Motherboard Replacement: adım 17, 1 resimden 1.
    • Using the black nylon spudger, lift the ribbon cable gently until it comes out.
  18. Canon PowerShot G7X Motherboard Replacement: adım 18, 1 resimden 1.
    • Remove the copper plate to reveal connections to the lens.
  19. Canon PowerShot G7X Motherboard Replacement: adım 19, 1 resimden 1.
    • Using the black nylon spudger, lift gently on the pin connector until it comes off.
  20. Canon PowerShot G7X Motherboard Replacement: adım 20, 2 resimden 1. Canon PowerShot G7X Motherboard Replacement: adım 20, 2 resimden 2.
    • Using the spudger, gently lift on the ribbon cable until it comes out.
    • Separate the lens from the motherboard.
  21. Canon PowerShot G7X Motherboard Replacement, Motherboard: adım 21, 1 resimden 1.
    • Remove the 5 mm Phillips #000 silver, anchor screws from the corners of the motherboard marked in the picture.
  22. Canon PowerShot G7X Motherboard Replacement: adım 22, 1 resimden 1.
    • Remove motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brandon Lacy
113 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S1-G5, Stella Fall 2019 IUPUI, Team S1-G5, Stella Fall 2019 üyesi
IUPUI-STELLA-F19S1G5
3 Üyeler
5 adet Kılavuz yazıldı
Bir Yorum
Very Good!
I Think I Want to DIY Rep My DC
sheep free - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 718
